finished wheels
Bodo Langbehn
Been liked: 25 times
finished wheels
Post by Bodo Langbehn »
Hi,
today I have finished the wheels for the 222.
One piece is coloured in primer red as a replaced wheel.
The spare wheel I have made some modifications in the inside and put the rivets into.Image
best Regards Bodo
Kent Wiik
Post by Kent Wiik »
:shock:
Those are 1:1?
If not then I am speechless!
scale modelling at its best bodo, i've been looking forward to your post, worth the wait regards simon manning.
Outstanding Bodo!
best regards
Has liked: 1495 times
Been liked: 1699 times
Incredibly realistic Bodo :!:
Did you have to make many custom tools :?:
Also, is the inner rim a separate turned fitting :?:
Bodo Langbehn
Hi Adrian,
as I tried to explain in the first posting: http://www.armortek.co.uk/forum/viewtopic.php?t=2320 , I have grinded two custom chisels to give the original wheel rims the design you see. Also I have turned four rings on my lathe and glued them into the modified wheel rims.
Kind Regards Bodo
