#055 Nears completion : )
keith d feucht
Post by keith d feucht »
Almost there; just some finishing touches to go.
Info on the 10 month build:
http://www.projecteagle.ca/tanks.html
Image[/url]
Chang
Has liked: 16586 times
Been liked: 487 times
Post by Chang »
Hi Keith,
It looks beautiful! Thanks for sharing these photos.
Are you planning to install motion/sound/smoke packs and let her moving around, or just let her stay on where she is?
Even a display-only model, she is about 140 kg. it's amuse me how did you move her at home, on carpet? :D
Lerh Chang
keith d feucht
Thanks for the post Chang. :D
Can you help me as I was trying to find the most up to date picture of your KT build in either a gallery or post?
For this year she will remain static. I pinned the suspension arms etc as per Dale Jordon's build so it's built to run, but we will see. It kind of looks nice dominating the room. I glass-beaded the tracks to get the sooty protective coating off, and use cardboard (just in case) when moving it around to protect the carpet.
If I keep this one static it will give me an excuse to pick up a future kit from Armortek and scale Maybach.
Has liked: 1495 times
Been liked: 1699 times
That's a great looking Tiger II Keith :D
I must admit I was a little worried when I realised it seemed to be upstairs :!: :!:
keith d feucht
Hi Adrian,
It had to partially come apart for that move! But actually, it only took about 4 hours, including re-assembly.
My alternative, if it is to be a runner, is to keep it in the basement. It will (just barely) fit through a window, and then out into the open air for some tempting fun. :D
