KT twin smokers
KT twin smokers
Has anyone plumbed the independant twin smokers together using a tee piece, we are about to fit the motion packs and wondered if there was any advantage in doing so or are they best left seperate, when you see video footage of the real thing the exhaust smoke is very often different as it leaves each stack, due I suppose to the two banks of cylinders running slightly differently at times? cheers Phil for Magpies Pyro
- Has liked: 1495 times
- Been liked: 1699 times
- Been liked: 1 time
Have you goten the smokers to work?
I might have done it wrong but when i tur with one track, the smokers stop wich is kinda annoying!
I might have with the fact that there is only one signal cable from the motors.
Im looking into if there is a way of getting rid of this with a relay or something.
Fredrik
Fredrik
