Hi chaps,
I've started my Late Tiger build, what sort of fit am I trying to acheive between the various hull panels?
As at the moment I have a few gaps (maybe .5mm) around the rear panel are these "normal" or should I be able to close them right up?
Adam
Starting my first build
- Been liked: 177 times
Hi Adam
Congratulations on your Tiger! There was another thread on a related subject under the "Tiger" section of the board. Hope it helps.
http://www.armortek.co.uk/forum/viewtopic.php?t=194
Have fun with your build.
Hi Tim,
Thanks for the link, I had already read it.
I'm still not sure what sort of tolereances i'm trying to work to though, in my line of work we aim to achieve a fit tolerance of under 40 microns, doesn't always happen though... I realise that I'm not trying to get that level of fit but what is considered "good" in the metal kit world?
Adam
Adam
- Been liked: 15 times
Hello Adam
These arnt Jet engines so just get the best fit you can get.My advise is to build it on a table that is flat an level then things will line up.
Lee
Lee
If its not broke dont fix it.
Ich Hatt Einen Kameraden
Hi Lee,
Thanks for the tip, I think I'm getting there now!
I stripped the hull back down and re-checked all the parts.
On closer inspection the floor had two small "bumps" on each side by the folds in the sheet, a small amount of filing got everything fitting much better, it's amazing how the effects of a tiny distortion get magnified further along in the build process.
I think I've still got a little adjustment to do on the rear plate to sort the back end out but I'm much more confident in what I'm doing now.
I had a look at the pics of your models, really impressive work!
Adam
Adam
Hello Adam
You can contact me on the phone if you want. see my website for number.Welcome to the world of 1:6th Scale.
Lee
Lee
