Exhausts
David Da Costa
Exhausts
Post by David Da Costa »
I have been looking at the exhausts for my PIII. The exhausts setup supplied with the kit appears to be wrong on two fronts.
1. The tail pipe should come out of the side of the box not the bottom.
2. The two exhaust boxes are two far apart and should be nearer to each other.
I intend to modify them to have the tail pipes coming out of the sides by just using the holes that are supposed to be plugged. Plugging the bottom holes and moving the holes for fixing them to the hull to allow them to be the correct distance from each other/ the tow hook cover that I made.
I will also need to modify the holes in the back to allow for them to match back up to the holes in the rear panel for the smoke system (if the rear hull panel was not all fixed down I would just have modified that).
