I've just dismantled the smoke generator on my Sherman and found that three of the air holes under the fan were blocked with a gel like substance, quite like vaseline.
Having run the generator on the bench, the smoke seems to condense on the inside of the lid , which is presumably why this gel forms.
So, if you're not happy with your smoke output, it's worth checking the holes haven't become blocked.
Smoke generator servicing.
- Has liked: 1363 times
- Been liked: 1556 times
- Been liked: 177 times
- Been liked: 10 times
I've made the UKTC designed smoke generator which uses a soldering iron element with fibreglass cloth as a wick over the element. For fluid I use a mix of baby oil and Maplins smoke fluid. I think what ever fluid you use the units eventually get quite dirty and smoke generating capacity diminishes, so regular servicing is needed. I've found it necessary to clean the muck off the element and to replace the fibreglass material and carefully clean the crud off everything, including the fan.
Allan Richards
