How I make tow ropes
Posted: Wed Apr 14, 2010 9:16 pm
Hi Guys
I was making tow ropes and I thought I would do a
mini how to do it.
So here is a little photo lesson.
First turn 9 mm stock to length in this case 40mm and add angle to one end.
Then drill a 3.3mm hole through. To clear the cable.
Drill a 6.7 mm hole from the other end 35mm deep.
Counter sink the 6.7mm hole end so the loop fits.
I buy the loop ends from B&Q in the UK they are 25mm dia.
pass cable through and loop loose end back into 6.7mm hole.
Fit the loop fitting.
Hold the body of the fitting and pull the cable tight. I then
heat up the fitting with a small blow torch and fill the fitting with soft solder.
Job done.
The sizes of the fittings given here are for my STUG build but
I have used the same idea for the Panther the only difference was
stock material used for the body.
I hope you find this interesting.
mini how to do it.
Job done.
