How I make tow ropes
Derek Attree
Has liked: 219 times
Been liked: 200 times
Post by Derek Attree »
Hi Guys
I was making tow ropes and I thought I would do a
mini how to do it.
So here is a little photo lesson.
First turn 9 mm stock to length in this case 40mm and add angle to one end.
Then drill a 3.3mm hole through. To clear the cable.
Drill a 6.7 mm hole from the other end 35mm deep.
Counter sink the 6.7mm hole end so the loop fits.
I buy the loop ends from B&Q in the UK they are 25mm dia.
pass cable through and loop loose end back into 6.7mm hole.
Fit the loop fitting.
Hold the body of the fitting and pull the cable tight. I then
heat up the fitting with a small blow torch and fill the fitting with soft solder.
Job done.
The sizes of the fittings given here are for my STUG build but
I have used the same idea for the Panther the only difference was
stock material used for the body.
I hope you find this interesting.
Has liked: 1479 times
Been liked: 1685 times
Excellent job Derek :D
Glad to see someone else has a 1/6th eye when wandering the DIY sheds :wink:
Has liked: 161 times
Been liked: 830 times
Derek,
Great looking cable, I made some similar ones for my Panther. I have yet to come across brass braided cable however. I used #6 braided copper electrical wire available at most hardware stores. After you strip off the insulation it is pretty close to "scale" for the Panther.
Great tutorial, and thanks for the ideas. Lovin that Stug!
Derek Attree
Hi Guys
The cable is uncoated steel 3.2mm dia and comes again from B&Q and costs about £1.40 per meter.
It is sold for up and over doors for garages.
Jim Fowler
Post by Jim Fowler »
Derek,
Thanks for sharing this - your work is awesome - I am going to try this.
Best Wishes!
Thanks,
Jim
Paul Morris
Been liked: 68 times
Post by Paul Morris »
Hi Derek.
Spot on mate...ha ha I came up with just the same method for the tow ropes I have made..."you can do it if you B & Q it" pretty good for spare belts for the power files too.
Cheers Paul :wink:
01524 720977
Nick Farrugia
tow ropes
Post by Nick Farrugia »
Hi derek
thats a good way to make them i think i will have a go
at making some for my pz111
regards nick
Derek, thanks for clarifying the material. It looks like brass in the photos. Kind regards, Bob
