In the Craftsman's Market section, Lawrence asked about numbers of castle nuts on the Pz III.
To reply to Lawrence:
I've only been able to look at my photos, so what follows may not be complete.
Pz III castle nut locations:
All cone head bolts used castle nuts on the inside.
Sprocket ring retainng bolts - 12 off each sprocket ring, so 24 per sprocket, 48 in total
Front and rear bump stop mounting bolts - 2 off each stop, 8 in total
Vorpanzer hull - 15 off (larger size?)
Vorpanzer turret if fitted - 16 off)
Lower bracket joining hull upper and lower units. These came in two types, the early scalloped version which was welded to the hull and a later, straight bracket which came with the later production hull without the side escape hatches. These simplified brackets were bolted to the lower hull. I think there are 10 off per side but I haven't got access to the Jentz and Doyle drawings. Someone might check this.
Return roller mounts - 3 off per mounting, 18 in total
Hull lifting hooks - 2 off per hook, 12 in total
Tracket adjuster mounting brackets - 6 off per bracket, 12 in total
Domed cover on the rear lower hull plate - 4 off.
Shock absorber upper mountings - 4 off per mounting, 16 in total
I haven't counted that lot up, but it must come to well over a 100.
Hope that helps. I'll post this on the Pz III section as well.
Castle Nut Quantities
- Has liked: 1024 times
- Been liked: 2094 times
