Sound unit
Posted: Sat Nov 03, 2007 11:07 am
by Andy Payne
Hey Guys , I have checked the forum for this problem and ask if anyone has more experience rectifying it.Bench tested my running gear today , all when fairly straight forward but for one point with the sound unit.With the engine sound running normally when I operate the turret traverse the sound unit restarts the engine.There was a previous post regarding this issue and it was identified that wiring capacitors into turret traverse motor would correct the problem.If this is the case could anyone advise me of the type/value of the capacitors to install.Everything else is going well and I'd hoped to move the tiger under her own power this weekend , but on Saturday arvo I discovered some fasteners missing and can't acquire any until Monday ,so I'll have to wait .Anyway thanks for any help in advance with my sound problem.
Posted: Sat Nov 03, 2007 12:42 pm
by Michael McGaren
Andy,
I had the same problem with my Sherman, this did work to solve the problem (so far so good anyway :D )
I used 0.1uF metalized film capacitors and a good silver solder. At first I used ceramic disc capacitors and a cheap rosin type solder that I had lying around, and it worked for a while but then stopped after a few days. Also scrape off some of the outer coating of the metal case on the motor so that you get a good connection.
I hope this helps,
Mike
Posted: Sun Nov 04, 2007 8:32 am
by Andy Payne
Thanks for your help Michael.Am I correct in understanding that you soldered these capacitors directly onto the motor casing?
Posted: Sun Nov 04, 2007 1:36 pm
by Michael McGaren
Andy,
Yes, one side of the capacitor to the motor casing, and the other to one of the terminals where the wire comes off. Then the other capacitor to the other terminal and then to the casing.
Good luck, I hope it solves your problem.
Mike
Posted: Sun Nov 04, 2007 10:02 pm
by Ad Wouterse
Hi guys,
One picture says more than a thousand words.
The values of the capacitators are an indication only.
Posted: Mon Nov 05, 2007 4:05 am
by Andy Payne
Thanks guys I'll have a crack and let you know how it went.
SOUND AND TURRET ROTATION
Posted: Fri Sep 05, 2008 9:21 am
by Graham Ord
Have followed your instructions and now have continuous sound. Thanks for the help I have received off various people.
Posted: Sun Sep 07, 2008 12:41 pm
by Roland Mann
Hi Everyone in charge with an early Tiger,
I got to the point to start my sound for the first time ever. However, in my chematic diagramm there are no colours and I wonder if the box is connected correctly. Can someone help me and check and let me know what is right. Any help is very much appteciated. Thank you and best regards
Roland
Posted: Sun Sep 07, 2008 3:31 pm
Roland.
This is somewhat unscientific but the colours on my Sherman sound unit follow your picture exactly.
The label attached to the top of the unit lists the connetions as:
7 - Blue - 0V
6 - Red - 24V
5 - White/Red - Function (I think this is for the engine start from the RC rcvr)
4 - Orange - Right Track
3 - Grey - Left Track
2 - Yellow - Loudspeaker
1 - Green - Loudspeaker
I've no reason to believe that the sound units from these two models should vary in their connections, though your box does seem to have two additional wires running in through grommets under the main connections :?:
Posted: Sun Sep 07, 2008 5:05 pm
by Roland Mann
Hi Adrian,
thank you very much for this check. Yes I believe the Sherman and early Tiger box are the same connections. Probably another Tiger owner will confirm. The numbers are of interest to me. There is another black/withe diagramm giving the numbers without colours. Will double check.
The two cables at the bottom of my box are my own additions. They are for my lights. The black is comming out of my own made main disrtibution box giving 3,3 volt from an extra BEC circuit for the lights, rear and front. The gray one leads to the rearlight. OK, I used Steve's beautiful front head lights but changed the bulbs for a less energy consuming LED in sunny white.
Thanks again for your help - Roland
HERES SOME MORE PHOTOS
Posted: Sun Jul 04, 2010 5:50 pm
by Graham Ord
Hi All
As you can see I soldered my capacitors to a band gripping round the motor on a roughened area to ensure contact.
The sound box is shown when temporary assembled by Mark at Armortek on his bench (thank you) and fitted to my P IV later at home.
Posted: Sun Jul 04, 2010 6:45 pm
by Allan Richards
Graham,
You could also put a third capacitor between the two motor terminals which I think is around 0.47 UF. If you go to a good model shop and ask for a suppressor kit for the motor on the normal RC electric cars they should be able to help. They work fine on the 24v tanks.
