Forpanzer for gun mantle
Lawrence Godson
Post by Lawrence Godson »
Hello to all,
I'm wondering if anyone has started thinking about the gun mantle forpanzer. It seems that some adjustments would be :
Add in the scalloped bottom edge.
Make it wider.
Make it less curved.
This probably would necessitate starting with at least new main and side pieces.
Lawrence Godson
Has liked: 1370 times
Been liked: 1567 times
According to a posting by Colin Fairweather on Dec 11, the mantlet shape was corrected on the second production run, so it might be worth checking with Gill if this is the case and whether there are any available.
colin fairweather
Been liked: 9 times
Post by colin fairweather »
hi adrian/lawence
that is correct mark did correct it for the second batch :D
colin :)
2006 222 SOLD
2009 pzr111 046 SOLD
Thanks Colin :D
Lawrence Godson
Yes, thanks Colin, I've asked Gill what the possibilities are for buying the update parts.
Lawrence Godson
Lawrence Godson
I'm wondering if anyone has built a PzIII from the second batch so that we could see the Vorpanzer
Lawrence Godson
Lawrence Godson
Gill has now informed me that the modified Vorpanzer armor plate for the mantlet which was included in the second run of the Panzer III might be available in the future if there is enough demand for it. Would anyone be interested in this? I would be for starters.
Lawrence Godson
Martin Diessel
Been liked: 21 times
Post by Martin Diessel »
I would be interesed, too. Depending on its price! Martin
Martin Diessel
How can I identify if my kit is the first or the 2nd batch?? The only thng I knwo is No2 of the prduced kits!
martin
Martin,
I think the first batch were sent out with five hole sprockets and the second batch to six hole sprockets.
Sarah Frazer
Been liked: 2 times
Post by Sarah Frazer »
Martin Diessel wrote:How can I identify if my kit is the first or the 2nd batch?? The only thng I knwo is No2 of the prduced kits!
martin
Hi Martin,
I guess yours is from the first batch as mine is serial number 77.
Sarah
Lawrence Godson
Hello Martin,
Another way to check for first batch or second batch is to see if the vorpanzer (the outer curved armored plate which fits over the base (mantlet) of the main gun) has a scalloped bottom edge. The second batch has this scalloped edge. the first batch vorpanzer has a smooth straight bottom edge. Gill says that they might produce a second run of these improved vorpanzers if there is enough interest. They probably have not worked out cost yet.
Lawrence Godson
John Cooper
Post by John Cooper »
Lawrence Godson wrote:Gill has now informed me that the modified Vorpanzer armor plate for the mantlet which was included in the second run of the Panzer III might be available in the future if there is enough demand for it. Would anyone be interested in this? I would be for starters.
Hi Lawrence
If the Vorpanzer is the right shape and size then count me in
John Cooper
Martin Diessel
Thanks I contacted Gill
Martin
Last edited by Martin Diessel on Sun Apr 04, 2010 12:57 pm, edited 1 time in total.
Hi Martin.
In a thread entitled "Sprockets" in this forum, where this difference in the number of holes was first identified, you will see Mark will make corrected sprockets available to anyone who requires them, so you should contact Gill for a pair of replacements.
