Can anyone help with where to buy this size of hinge, width is 17MM and I need it be no shorter than 200MM in length, as you can see their are 4 joints to 25MM.
Just saw this post, these model airplane hinges and I beleive are made in China, the actual hinge is some sort of alloy coated to look like brass, the hinge pin is iron or steel a rusts very easily. If you use these I recommend changing the hinge pin to a brass one as soon as you get it.
If they are all brass please let me know, the ones I purchased here in the US were not and I originally used them on my Tiger I mudguards and found they rusted which is why I ended up making my own custom ones for the mudguards.
To answer all the questions, this company sells two sizes, I bought both sizes and found it is the larger one that meets my 6th scale needs, please note(My 6th scale needs). I am using it for the rear tyre door on the Sdkfz 7 and also on my King tiger rear mudguards.
Mike,
I have cut into it it and it looks like brass, according to the web page it is from a Spanish suppler. you might be better going direct as they are not cheap at £5 a foot.
