I've finally managed to get the recoil system on the prototype Sherman working as I would like.
When I initially stripped the tank down, it looked like this:
Now I've cleaned up the parts and replaced the servo, it looks like this:
This is the unit in operation:
The servo is a Sanwa ERG-VRX, which is supposed to operate at 0.06 seconds per 60 degree arc but I don't think it's quite that fast. The servo is being controlled by a PICAXE 08 chip, hence the dual speed operation. To get the best from the servo, I'm running the whole circuit from 6 volts but I think it would be safer for the rest of the electronics if I create a split supply.
For those wondering why their Sherman doesn't have a recoil system, I believe this was superseded by the blank firer before the Sherman kit was released.
Personally, I'm torn between leaving it as it was originally designed or changing the length of the arm attached to the servo, to increase the speed of attack.
Sherman prototype recoil
- Has liked: 1484 times
- Been liked: 1693 times
Last edited by Adrian Harris on Mon Mar 23, 2020 11:16 am, edited 1 time in total.
One of the handy things about the PICAXE is that it can read RC servo signals, so it should be possible to link it to the receiver and synchronise them that way.
One slight hiccough is that the original Sherman sound system doesn't have a built-in main gun sound, just the machine gun, so I may have to improvise
Last edited by Adrian Harris on Sat Feb 06, 2010 10:39 pm, edited 1 time in total.
- Been liked: 15 times
Hello Adrian
I have a Benedini in mine its a great improvement on the original armortek version.
Lee
Lee
If its not broke dont fix it.
Ich Hatt Einen Kameraden
- Has liked: 161 times
- Been liked: 830 times
- Been liked: 10 times
Adrian,
Thats a nice little recoil unit, if you connect the servo to a non proportional channel it won't be difficult to manually synchronise the sound and movement if you fit either the Benedini unit system or a Tamiya system. For my Sherman I bought a Tamia Sherman kit and used the electronics then sold on the Kit as a static model on e-bay. I got a good price so the sound system came very cheap and it also has a muzzle flash that you can mount in the gun as well.
Allan Richards
recoil unit
Hi adrian
i like your recoil system it looks very smooth you have done a great job repairing it and putting it back into working order.
do you think a system like that would work and fit in my pz111.
great job
regards
nick
great job
regards
nick
