Suitable glue for 3d printed parts.
Posted: Thu Jan 28, 2010 7:05 pm
As it seems that several people here seem to have experience of 3d printed parts, could I request some advice on a suitable glue for these type of parts :?:
The Sherman prototype I am renovating has 3D printed engine hatches and the hinge side of one of these has snapped off:
I plan to glue it back together and, once fixed, drill through the two sides and insert metal pins to provide some mechanical strength. However, I'm not sure what sort of glue is suitable for this material :?:
Posted: Thu Jan 28, 2010 9:12 pm
by Robin Hinson
Hi Adrian,
You could try JP Weld which very strong and it comes in two small tubes. Mix equal parts, this dries in about 6 hours. Or they do a similar product called JP Quick which dries in 15 minutes. Both can be obtained at Motor Accessory shops.
Best Wishes
Robin Hinson
Posted: Thu Jan 28, 2010 9:22 pm
by Steve Norris
Hi Adrian
If i am not mistaken the 3D printed parts are made of some form of plastic, it may be worth a try using plastic weld which can be obtained from most good model shops.
When i first saw the photo i thought it was a real Sherman being restored, its almost a shame to remove the rust :roll:
Posted: Fri Jan 29, 2010 9:49 pm
by David Skeldon
Hi,
I have a couple of the metal armortek grills spare if you want them.
Posted: Fri Jan 29, 2010 9:59 pm
Hi David.
Thanks for the offer but I'm trying to keep as many of the original parts as possible.
I'll have some spares too, once I've converted one of my hulls to an M4A2.
Oh, and I love your jack-in-the-box flail commander :D Any chance of a description of how it works :?:
Posted: Fri Jan 29, 2010 10:14 pm
by Brian Leach
How did you get such realistic rust-excellent! :wink:
Brian
Posted: Fri Jan 29, 2010 10:25 pm
http://www.armortek.co.uk/gallery/main. ... emId=11309 :wink:
I'm having to treat everything with oxalic acid to get rid of it :!:
Posted: Sat Jan 30, 2010 4:14 am
by Sarah Frazer
Hi,
At the Model Engineering Exhibition there was a stand which did 3D printing and they said the material used was ABS plastic. Devcon do a Plastic Weld which states is good forABS.
Regards,
Sarah
Posted: Sat Jan 30, 2010 7:52 am
by Armortek
Hi
Yes it is ABS plastic. The best adhesive that we have found is a CA, any thick grade of superglue.
