Suitable glue for 3d printed parts.
Has liked: 1480 times
Been liked: 1685 times
As it seems that several people here seem to have experience of 3d printed parts, could I request some advice on a suitable glue for these type of parts :?:
The Sherman prototype I am renovating has 3D printed engine hatches and the hinge side of one of these has snapped off:
I plan to glue it back together and, once fixed, drill through the two sides and insert metal pins to provide some mechanical strength. However, I'm not sure what sort of glue is suitable for this material :?:
Robin Hinson
Been liked: 1 time
Post by Robin Hinson »
Hi Adrian,
You could try JP Weld which very strong and it comes in two small tubes. Mix equal parts, this dries in about 6 hours. Or they do a similar product called JP Quick which dries in 15 minutes. Both can be obtained at Motor Accessory shops.
Best Wishes
Robin Hinson
Steve Norris
Has liked: 8 times
Been liked: 701 times
Post by Steve Norris »
Hi Adrian
If i am not mistaken the 3D printed parts are made of some form of plastic, it may be worth a try using plastic weld which can be obtained from most good model shops.
When i first saw the photo i thought it was a real Sherman being restored, its almost a shame to remove the rust :roll:
David Skeldon
Has liked: 33 times
Been liked: 312 times
Post by David Skeldon »
Hi,
I have a couple of the metal armortek grills spare if you want them.
Hi David.
Thanks for the offer but I'm trying to keep as many of the original parts as possible.
I'll have some spares too, once I've converted one of my hulls to an M4A2.
Oh, and I love your jack-in-the-box flail commander :D Any chance of a description of how it works :?:
Brian Leach
Been liked: 3 times
Post by Brian Leach »
How did you get such realistic rust-excellent! :wink:
Brian
http://www.armortek.co.uk/gallery/main. ... emId=11309 :wink:
I'm having to treat everything with oxalic acid to get rid of it :!:
Sarah Frazer
Been liked: 2 times
Post by Sarah Frazer »
Hi,
At the Model Engineering Exhibition there was a stand which did 3D printing and they said the material used was ABS plastic. Devcon do a Plastic Weld which states is good forABS.
Sarah
Been liked: 3694 times
Hi
Yes it is ABS plastic. The best adhesive that we have found is a CA, any thick grade of superglue.
