I have a Robbe Futaba FF7 2,4 GHz Radiocontrol and a Benedini Soundmodul on my Tiger.
All the Time i can play only one Sound :Engine start on-off. It works very good with the
Main Motors,but I can't start any other of the 11 sonds.On Saturday I found out howto do this.
My Soundmodul is on Channel 5, and channel 5 is the switch "E".
Switch -E has 3 ways (down-middle-up) and 3 Switching directions ( On-Off-Off; On-On-Off;
Off-On-Off ).
Under "Parameter"can you change the Switches for channel five and seven,but not the directions.
You must go to another section like "Throttle cut"( have no function on elektric motors).Set
" Rate" to 0% and change the switch to "E".Now you can choose the direction = Off-On-Off.
In this way my E-Switch have full function to the twelve sounds.
-1. engine start = one click down (choose), middle (wait),one click up (start the sound)
-2. step on the gas = first start engine (1.)then, two click down ,middle,one click up (start
the sound)
-3. full Throttle = first start engine (1.)then, three click down,....
-4. Main Gun fire = four click down .....
-5. MG 42 fire = five ...
-6. MG 34 fire
-7,8,9 = Radiagrams (i understand only one )
-10. = Garnet Impact ( ? I hope so ? )
-11. = Horn
-12. = Garnet Impact
Sound 2 and 3 only function who the Engine is start.All the Sounds can played together with the
Engine Sound. I think on other Radiocontroller the process is the same. I hope that could help
some people.
