Hello,
now I have available my track-links. I can offer You the following:
-Track-set, 115left/115right (96 + spares per side), shim-set steel to add on pins, shim-set brass to adjust link-gap, pin-rod-lenghts from hard-brass to make pins and a 4,1mm long-drill to hone-out the holes.
for 2380Euro + shipping.
Please allow 6 weeks for selection/packing/shipping.
The tracks are from heavy-duty steel/investment-casting, 100% accourate in every detail, exact 3D-copy from original item with minor adjusting to match the Amorteks Kingtiger geometry (please note: The amortek-Sproket-rings are not usable / does not match in diameter). The links come finished and sand-blasted, just to have a little drill-out with 4,1mm of the casted pin-hole to remove some stain and roughness.
Do not hesitate to ask me any question You may have and send me an email and I return You some pictures asap.
Email me to: op@piekenbrink.de
With kind regards, Olaf
Kingtiger late-style tracks
- Been liked: 1 time
Last edited by olaf piekenbrink on Fri Nov 20, 2009 6:44 am, edited 1 time in total.
- Chang
- Has liked: 16035 times
- Been liked: 452 times
Hello Lerh,Chang wrote:Hi Olaf,
Is the 18-teeth sprocket ring the next project?
Thanks!
Lerh Chang
many thanks for your message.
Yes, I work on the dimensional geometry/doing 3D-drawing at the moment. No idea if I make sets of rings and sell them or provide/sell the 3D-datas, only.
with kind regards , Olaf
Olaf Piekenbrink
- Has liked: 130 times
- Been liked: 780 times
