Hi All,
Some of you might have seen my front Notek demonstration example at the Armortek open day.
Using the superb white metal Notek supplied by Dave Dibbs of Armorpax as a starting point. I have machined out the interior of the Notek casting, made a replacement front window and base. Drilled a feed hole for the wiring and inserted a 12v bulb and translucent lens. The result is a well detailed Front Notek with working light. I will be producing the Noteks, complete, machined castings and new base, light and lens, for £45.00. I have left the parts unassembled to aid painting. The parts can then be simply glued together.
For orders or further information on this and other tank parts that I make, please e mail me at:
timcatton@tiscali.co.uk or
tim.catton@epr.co.uk.
Illuminated front Notek
- Been liked: 30 times
notek lights
Hi Tim,
Did you get the cheque I sent, I think not as I have had no word from you.
I will post a new one over the weekend .
Regards Roy
Regards Roy
It could be worse, It could be Tuesday.
- Been liked: 2 times
Notek light
Hi Leon.
I have 3 Notek lights from Tim and you will not be sorry you got them. They are fantastic too look at and look a treat.
Regards Roy
Regards Roy
