lighting switch
lighting switch
can anyone show with a picture the way to hook up the headlight and tail light on panther to the r/c switcher unit. power in and light circut
- Been liked: 177 times
Hi Mark
I used a simple RC switch. It comes with RC type plug and plugs into the receiver. It is then wired to the power source(in my case a 9 volt battery) and the two lights (front and rear convoy lights). Pick a channel on your Radio unit with a simple two-way switch and you are done.
Here's the one I used and where I purchased it. They are a great source for lots of cool stuff.
http://www.robotmarketplace.com/product ... TLSW1.html
If I get a chance to pull the turret and deck from my Panther I'll take a photo.
- Been liked: 15 times
Hello Mark
I just use an extra switch unit supplied by Armortek. Simples.
Electrlize one.
Lee
Electrlize one.
Lee
If its not broke dont fix it.
Ich Hatt Einen Kameraden
Hello Mark
You need a seperate switch unit. Terminals used are NO and RLA or RLD.
I use a small 3.2Ahr battery and put a fuse in and the + onto RLA off on NO and then onto the feed to the convoy and headlight. - back to the - on the battery.
Lee
Lee
