88 mm Ammunition Tiger 1 and 88 Flak
Mike Stannard (toyrific)
The 88 mm Tiger 1 and 88 Flak ammunition is getting low on stock of brass and steel shell cases. It is unlikely I will make more as the minimum run I can make is 500 of each part and I do not think this is a viable number for me to stock in the future.
As Tim Bowman (Aka The Ammo Man) is making such fantastic rounds and boxes I have decided not to make any more ammunition and did a deal with Tim to make the Tiger 2 rounds and gave him my masters to work with, you can see from Tim's post he did a great job on these as with his other rounds and boxes.
Current stock of my rounds is listed below with pictures and what is now available. I only have 16 steel and 150 brass shell cases in stock and I am reserving this for the HE round only. I ran out of metal AP projectiles some time ago and replaced them with resin cast ones. These are available only with copper shell cases or painted brass cases. The price list below replaces prices listed in my on line catalog.
Here are pictures of rounds with decals applied and details of the HE projectile.
Decals available (Gray lettering on decals is White)
88 mm AP Tiger 1 (Full round)
88 mm AP Tiger 1 (Shell case only)
88 mm HE Tiger 1 (Full round)
88 mm HE Tiger 1 (Shell case only)
Each set of six decals comes with different fill dates. See sample
For those interested here is what the dates and lettering means. These are the notes I used to make the decals
AP Round
HE Round
HE and AP Round Base
Note the lettering on 88 Flak rounds would be different.
New prices and availability
88-36AP-B1 88 mm Kw.K 36 AP Round with Metal Painted Brass Case & Resin Projectile 11.95
88-36AP-B10 88 mm Kw.K 36 AP Round with Painted Brass Case & Resin Projectile X 10 110.00
88-36AP-S1 88 mm Kw.K 36 AP Round with Steel Case Not Available
88-36AP-S10 88 mm Kw.K 36 AP Round with Steel Case X 10 Not Available
88-36AP-C1 88 mm Kw.K 36 AP Round with Copper Case & Resin Projectile 9.95
88-36AP-C10 88 mm Kw.K 36 AP Round with Copper Case & Resin Projectile X 10 95.00
88-36C-B1 88 mm Kw.K 36 Empty Painted Brass Case 9.45
88-36C-B10 88 mm Kw.K 36 Empty Painted Brass Case X 10 90.00
88-36C-S1 88 mm Kw.K 36 Empty Steel Case Not Available
88-36C-S10 88 mm Kw.K 36 Empty Steel Case X 10 Not Available
88-36C-C1 88 mm Kw.K 36 Empty Copper Case 7.45
88-36C-C10 88 mm Kw.K 36 Empty Copper Case X 10 70.00
88-36HE-B1 88 mm Kw.K 36 HE Round with Brass Case (All Metal) Only 150 in Stock 24.95
88-36HE-B10 88 mm Kw.K 36 HE Round with Brass Case X 10 (All Metal) 240.00
88-36HE-S1 88 mm Kw.K 36 HE Round with Steel Case (All Metal) Only 16 in Stock 24.95
88-36HE-S10 88 mm Kw.K 36 HE Round with Steel Case X 10 (All Metal) 240.00
88-36HE-C1 88 mm Kw.K 36 HE Round with Cooper Case (All Metal) 22.95
88-36HE-C10 88 mm Kw.K 36 HE Round with Cooper Case X 10 (All Metal) 200.00
88-DECAP 6 Tiger 1 88 mm AP Round Decal set of 6 9.95
88-DECAP1 Tiger 1 88 mm AP Round Decal 2.00
88-DECHE 6 Tiger 1 88 mm HE Round Decal set of 6 9.95
88-DECHE1 Tiger 1 88 mm HE Round Decal 2.00
88-DECAP-C6 Tiger 1 88 mm AP CaseDecal set of 6 7.50
88-DECAP-C1 Tiger 1 88 mm AP Case Decal 1.50
88-DECHE C6 Tiger 1 88 mm HE Case Decal set of 6 7.50
88-DECHE-C1 Tiger 1 88 mm HE Case Decal 1.50
I have also posted this list with my on line catalog which includes some other price increases and corrections.
Mike
