Wiring problems
David Hopkins
Wiring problems
Post by David Hopkins »
Can anybody help, I've wired up the sherman, I can get the tank to go forward, backwards, left and right, I can get the heating eliment to work in the smoke machine, but I can't get the sound to work, the tarret rotation,the gun elevation to work or the motor for the blank firing system to work.
Any Ideas?
-Dave
Has liked: 1480 times
Been liked: 1685 times
Hi David.
Have you got a servo you can use to test the outputs of the receiver channels - to see if they are responding as you operate the transmitter :?:
Do the Electronize relays click when you operate the channels (I can't remember for sure but I think they should) :?:
Do you have a meter you can use to check that 24V is getting to the Electronize units :?:
