this is one of the little jobs, that you think will only take about 1/2 an hour; the linkage is on both sides of the 222, and situated below the doors, to have it functional the main lever has to have "V" shaped ends holding the pivot pin, and this is drilled and tapped to take the push rods, about 3 hours work and one more job out of the way
regards
Jeff
