rear mud guards
Jeffrey Goff
Has liked: 20 times
Been liked: 737 times
rear mud guards
Post by Jeffrey Goff »
Its been a couple of weeks since last got a chance to do some modelling, and one of the things I noticed was the large gap around the exhaust box compared to the original, so I soldered in a shaped metal plate, and I think it looks better, I also made a start on the metal stowage boxes, this is how far I got tonight
regards
Jeff
dont be surprised if you wake up one morning and my 222 is outside your house in a box ,with a note stuck on it,which reads,please finish,always interesting.simon manning.
Jeffrey Goff
Has liked: 20 times
Hi Simon, that made me smile, and then I thought, he would not do that, then with the realization that he might, I changed my address, only joking Simon, the bits arrived safely today
regards
Jeff
Ad Wouterse
Been liked: 2 times
Post by Ad Wouterse »
Hi Jeff,
Very, very impressive :D . You keep inspiring me for my 222.
Where did you find those nice small latches ?
Keep up the good work :wink:
Ad
Jeffrey Goff
Has liked: 20 times
Hi Ad, the brass latches are from Mike Stannard, I just shortened and re-drilled the levers
regards
Jeff
Allan Richards
Been liked: 10 times
Post by Allan Richards »
Supurb again Jeff. I was looking at the top picture with the whel off, a couple of nuts screwed back on the studs, the dark "dirty" suspension, it could easily be mistaken for a 1:1 restoration!!
Allan Richards
Ad Wouterse
Been liked: 2 times
Hi Jeff,
They looked familiar, but I got confused by the size of the lever.
Thanks !
Ad
Jeffrey Goff
Has liked: 20 times
As I have to work this weekend I got up early and finished most of the building on the back end, and just in case it looks like being completed some pictures from the front
regards
Jeff
Has liked: 161 times
Been liked: 846 times
Jeff,
Your details are really bringing the 222 to life. Excellent work on the boxes and exhaust pipes. What theater of operations are you going to paint it? Hopefully western front! I like the mini tread plate too!
Hi Jeff,
Amazing as always. I thought the close up picture was a real one at first glance. I'm with Bob. Western front! :D Your 222's interior will be fun to watch as it receives more detail with every post.
best wishes
Jeffrey Goff
Has liked: 20 times
Hi Bob & Tim, I had not thought of doing a Western front model, I was only trying out some spray paint bought in Germany, and the number plates I bought about two years ago, but on checking the SS were still using the 222 until September 1944, so a three colour Camo it will be
check out this site for paint
this is the ebay number 370157495050
and the seller is HEERESZEUGAMT, 400ml spray can, four times the size of Tamiya, approx 9 Euros, if you read the blurb, which is also in English, it is supposed to have the same properties as the original paint
regards
Jeff
