As mentioned above i have devised a way of modifying the assembly of the type X and Y wheels, this mod allows the wheels to be more easily assembled and more importantly disassembled for servicing.
Stage 1 , Open up 11 holes in the sequence shown in the outer face of 8 type X and 8 type Y wheels. The holes should be a clearance fit for the head of a M3 cap head bolt in the type X wheel and a clearance fit for the head of a M2.5 slotted scew in the type Y wheel. The holes should be deep enough so that the fastener heads will be just below the surface of the wheel hub mounting face.
Next flip the 16 modified wheels over and drill 3 holes in each in the positions shown, each hole should be deep enough for the head of a 6BA bolt.
Each of the 16 wheels should have 3 6BA x 3/8 bolts glued in as shown.
This shot shows the outside of a wheel after the 6BA bolts have been fitted.
Fit 8 inner type X wheels to the hubs with the supplied fasteners and tap 11 holes M3 at the outer end, these holes should allign with the remaining holes in the outer wheel.
The outer type X wheel can now be fitted using 11 M3 fasteners. 2 are shown fitted here.
The hub cap can now be fitted using the 3 6BA bolts and nuts.
The type Y wheel build up uses the same principle as the type X the only difference is that the inner ,outer and hub are bolted together as a assembly prior to fitting the hub cap.
Hope all this is clear
