Charging socket
Derek Attree
Has liked: 219 times
Been liked: 200 times
Charging socket
Post by Derek Attree »
Hi Guys
I am just wiring up the Panther and I was wondering if anyone has added a
charging socket for the main drive batteries so they can be charged without removing the deck of the tank each time.
If so do you need to have a way of isolating the other electronics.
I have the old style control box and I am using an acumate 24 v charger.
leesellars
Been liked: 15 times
Post by leesellars »
Hello Derek
You have to isolate the mains electics. Use the plug provided.
Lee
If its not broke dont fix it.
Ich Hatt Einen Kameraden
Has liked: 1495 times
Been liked: 1699 times
I've not done this myself but I think the easiest way to achieve this would be to insert a Double Pole, Double Throw (DPDT) switch into the battery leads to the main control box.
Wire the battery leads to the common terminals.
Wire the control box to one set of switched terminals.
Wire the charging socket to the other set of switched terminals.
Then you can switch the batteries between the tank and the charging socket.
DPDT switches normally have two positions, such that the centre common terminals are connected to one or other of the switched terminals. If you can find a "Centre Off" switch DPDT switch, then when the switch is in the middle position, the batteries are isolated from both the charging socket and the control box.
You are unlikely to be operating the switch when there is a heavy current passing through it but I would recommend fitting the highest current rated switch that is available, simply because the higher the current rating, the larger terminals it will have and so it will be easier to connect the chunky leads associated with the power systems in these tanks.
Robin Ellis
Been liked: 8 times
Post by Robin Ellis »
I use the accumate waterproof connector, available for £5.87 and available from www.bykebitz.co.uk They are excellent and fit straight on to our chargers. :o
Graham Ord
Has liked: 4 times
Been liked: 16 times
CHARGING
Post by Graham Ord »
If, like me, you have lead acid batteries you have to take the top deck off to remove the battery breather plugs as they blow off if left in.
Graham
Robin Ellis
Been liked: 8 times
Derek, I have just noticed that they are only £4.60 from www.accumate.co.uk
Paul Morris
Been liked: 68 times
Post by Paul Morris »
Hi Fellas.
Just my two pence worth, i am with Robin on this the item he has directed you to is dead simple to fit and works a treat, i have three set up and never had any trouble.
Cheers Paul :wink:
01524 720977
Derek Attree
Hi Guys
Thanks for the Info I have it sorted now
