I finished the suspension, not quite as straight forward as I thought, as the springs and housings are visible through the wheel arch I wanted to do away with the long bolts that went through the springs and housings, and replace with working dampers, and proper brackets to the top, to get everything in alignment, I had to raise the top wishbones, and added the stop across the two spring housings, these are the results, the prototype body still has the plastic fittings, will start this once I have worked out how to make the steering gear
regards Jeff
