Hi, im building the skzd 7 and assured the boss that there would not be any more expenditure as I had the radio. Turns out that my Futaba 40MHZ T7CP set is defunct, rather the receiver is. Seems 40MHZ receivers are no longer available. Will the 2.4MHZ sets work on Armorteks controllers?
Thanks in advance
Radio set help
- Has liked: 50 times
- Been liked: 144 times
- Andre Meylan
- Has liked: 802 times
- Been liked: 362 times
Re: Radio set help
Hi Colin - no problem with that, works perfectlyColin Stevens wrote: ↑Sat Mar 15, 2025 12:34 pmHi, im building the skzd 7 and assured the boss that there would not be any more expenditure as I had the radio. Turns out that my Futaba 40MHZ T7CP set is defunct, rather the receiver is. Seems 40MHZ receivers are no longer available. Will the 2.4MHZ sets work on Armorteks controllers?
Thanks in advance
Best regards, Andre
- Andre Meylan
Re: Radio set help
Hi Colin - any radio system will work, there is no incompatibility with the radio. Just choose one with which you are familiar and have enough channels for all your functions. Mixing might be needed as you want to put forward/backward and steering on one stick? I use a 15 year old Futaba FX-32 with 2.4 GHz and dual receivers. But there are more experienced colleagues on the forum here ...
Best regards, Andre
Best regards, Andre
Re: Radio set help
Just what I wanted to hear. Seems that Futaba may be the more viable option. Just an expense I assured the boss I wouldnt have to pay. But now im going to pay, oh boy will I!Andre Meylan wrote: ↑Sat Mar 15, 2025 2:45 pmHi Colin - any radio system will work, there is no incompatibility with the radio. Just choose one with which you are familiar and have enough channels for all your functions. Mixing might be needed as you want to put forward/backward and steering on one stick? I use a 15 year old Futaba FX-32 with 2.4 GHz and dual receivers. But there are more experienced colleagues on the forum here ...
Best regards, Andre
Online
I use the Spektrum DX9 transmitter on my Armortek models....works absolutely fine.
- Has liked: 134 times
- Been liked: 137 times
Re: Radio set help
Hi Colin,Colin Stevens wrote: ↑Sat Mar 15, 2025 12:34 pmHi, im building the skzd 7 and assured the boss that there would not be any more expenditure as I had the radio. Turns out that my Futaba 40MHZ T7CP set is defunct, rather the receiver is. Seems 40MHZ receivers are no longer available. Will the 2.4MHZ sets work on Armorteks controllers?
Thanks in advance
