Torsion bars
Dan Williams
Torsion bars
Post by Dan Williams »
Does anyone know what material the torsion bars are made from?
Thanks Dan
Matthijs Dijkstra
Been liked: 2 times
Post by Matthijs Dijkstra »
Hi Dan,
It is spring steel if I'm not mistaken!!
Matthijs
Allan Richards
Been liked: 10 times
Post by Allan Richards »
I think its a material called piano wire which is a high carbon steel.
Allan Richards
Been liked: 3695 times
Dan
The material is spring steel, not piano wire.
Dan Williams
Thanks Mark,Knowing the material type was a big help.I have the suspension done.I use a small mill and a fixture to put the flats on the
bars.This is easier then filing,and looks better.
Dan
Rich Stinchcomb
Has liked: 3 times
Been liked: 1 time
Post by Rich Stinchcomb »
The transition from flat to the rest of the torsion bar should be gradual. A sharp machined edge could cause the torsion bar to break. The flat should be as smooth as possible for the same reasons.
"All you saw in your imagination was the muzzle of an 88 behind each leaf." - British Tank Commander Andrew Wilson
