My Leopard 2A4 photos
Chang
Has liked: 16515 times
Been liked: 487 times
Post by Chang »
Hi, I am really paying some attentions on the track tension. Here are some photos of my Leopard 2A4 (Chassis only , with 82 track links as the real tank).
No test driving yet. So far looks OK (to me :wink: ). Sorry about the painting ..... :oops:
The RHS track.The space between the top of track and sponson is very tight :
Leopard 2A4-34.JPG (111.8 KiB) Viewed 526 times
Same right track , with the side skirts down :
Leopard 2A4-40.JPG (85.37 KiB) Viewed 526 times
Middle section of the right track. See the track pad above the support roller almost touch the sponson. Is it OK?
Leopard 2A4-35.JPG (107.37 KiB) Viewed 526 times
Middle of the left track. Similar with the right track :
Leopard 2A4-36.JPG (114.59 KiB) Viewed 526 times
View from the left back :
Leopard 2A4-37.JPG (124.18 KiB) Viewed 526 times
View from the right back :
Leopard 2A4-38.JPG (90.81 KiB) Viewed 526 times
View from behind. I know the painting is not impressive....
Leopard 2A4-39.JPG (87.89 KiB) Viewed 526 times
Comments and suggestions are all welcome.
Lerh Chang
Martin Donnison
Has liked: 40 times
Been liked: 108 times
Re: My Leopard 2A4 track tension photos
Post by Martin Donnison »
Hi lerh, I recently asked this question and was told it should be between 10mm to 20mm measured on the middle at the top of the track. I set my tracks similar to yours and it didn’t sound right. I will drive it again with this measurement and let you know how it goes.
Thanks Martin.
Martin Usher
Has liked: 25 times
Been liked: 62 times
Post by Martin Usher »
Chang, just a quick question, why 82 links not 81 as AT recommend ?
Martin.
Chang
Post by Chang »
Martin Usher wrote:
Fri Oct 18, 2024 4:35 pm
Martin.
Hi Martin,
81 is Armortek's recommendation. 82 is the number of the real tank. I just wish to find out if 82 is OK too on 1/6 model. If it is not , I'll go down to 81.
With regards,
Lerh Chang
Chang
Re: More Leopard 2A4 photos
Post by Chang »
Just add some photos :
Hull top deck. Some minor details added.
Leopard 2A4-47.png (852.02 KiB) Viewed 788 times
Again , hull top deck. Turret ring shell guard updated.
Leopard 2A4-48.png (809.54 KiB) Viewed 788 times
Preliminary front interior conceptual layout. Sorry about the mess.
Preliminary rear interior conceptual layout. Cover net added on two speakers.
So far meet a small issue about the recoil gun barrel adaptor XRE028-Leo and Kian will help to sort it out.
Lerh Chang
Rear panel. Mud flaps details added.
Leopard 2A4-46.png (740.73 KiB) Viewed 788 times
Chang
Post by Chang »
One more photo :
For all six side skirts , add some details to simulate the real things :
Add 2mm cut PVC tubes along the bottom edge; and
Add M3 rectangular washer beneath each M2.5 screw hex bolt.
See Andre Meylan's Pz 87 photo (and enlarge it) , you'll see what I have done :
Lerh Chang
Chang
Re: My Leopard 2A4 photos
Post by Chang »
I have edit photos of 18 Oct 2024 for better quality . :mrgreen:
