T5 audio module
Posted: Mon Apr 22, 2024 9:05 pm
by David Gray
Whilst running my panzer111 this weekend
The sound started to fade away then disappear
Altogether, has anyone else had this problem
And can it be fixed
Re: T5 audio module
Posted: Mon Apr 22, 2024 10:23 pm
Do you mean the TBS5 ?
The last two sounds, 11 and 12 from memory, are software driven volume controls.
If you select I believe 11 is volume down and 12 is volume up, but it's a long time since I've used a TBS5 based system.
Try selecting sound 1, so that the engine sound should be playing. Then select and hold sound 12, as if you wanted it to repeat, and see if the volume returns. If that doesn't work, try doing it with sound 11.
Re: T5 audio module
Posted: Tue Apr 23, 2024 8:42 am
by David Gray
Hi Adrian do you mean selecting the sound on the 3 way
Switch on the transmitter
Re: T5 audio module
Posted: Tue Apr 23, 2024 9:43 am
Yes.
Re: T5 audio module
Posted: Tue Apr 23, 2024 11:49 am
by David Gray
Thanks Adrian , selecting position 11 and holding
Has rest it
Re: T5 audio module
Posted: Tue Apr 23, 2024 12:06 pm
by David Gray
It’s reset works fine now
Re: T5 audio module
Posted: Tue Apr 23, 2024 12:11 pm
Great
