Sprocket rings for Olaf king tiger steel tracks
Posted: Thu Mar 28, 2024 5:35 pm
by David Brady
Hi
Two sets of sprocket rings, one set is as supplied by Olaf for his steel single piece tracks and the other set is a smaller to scale set that may work with his tracks(sold)
One original as supplied by olaf set left as pictured £75 plus postage
Re: Sprocket rings for Olaf king tiger steel tracks
Posted: Fri Mar 29, 2024 4:16 am
by Chang
Hi David. PM sent again on March 31.
Kind regards,
Lerh Chang
Posted: Mon Apr 01, 2024 11:50 pm
by Chang
Hi David,
A new PM sent. Please acknowledge.
Kind regards,
Lerh Chang
Posted: Tue Apr 02, 2024 6:25 am
by David Brady
Hi Chang
Received and replied.
Posted: Tue Apr 02, 2024 10:41 pm
by Gerhard Michel
Just a hint: I'm using Olaf's steel track links on three models of mine with best results. The original sprocket rings have good running characteristics when remaining 'untuned'. Other shapes of teeths may be not as good. Pointed teeth for the King Tiger were also tested by German army; there are rare pics available.
For my non-AT models I had to create sprockets of my own for Olaf's track links, and I copied this tooth shape. The only modification was some tapering of the tooth flanks.
