Hi
Two sets of sprocket rings, one set is as supplied by Olaf for his steel single piece tracks and the other set is a smaller to scale set that may work with his tracks(sold)
One original as supplied by olaf set left as pictured £75 plus postage
Sprocket rings for Olaf king tiger steel tracks
- Has liked: 200 times
- Been liked: 793 times
- Chang
- Has liked: 16337 times
- Been liked: 477 times
Re: Sprocket rings for Olaf king tiger steel tracks
Hi David. PM sent again on March 31.
Kind regards,
Lerh Chang
Kind regards,
Lerh Chang
- Chang
Hi David,
A new PM sent. Please acknowledge.
Kind regards,
Lerh Chang
Kind regards,
Lerh Chang
- Gerhard Michel
- Has liked: 3 times
- Been liked: 670 times
Just a hint: I'm using Olaf's steel track links on three models of mine with best results. The original sprocket rings have good running characteristics when remaining 'untuned'. Other shapes of teeths may be not as good. Pointed teeth for the King Tiger were also tested by German army; there are rare pics available.
For my non-AT models I had to create sprockets of my own for Olaf's track links, and I copied this tooth shape. The only modification was some tapering of the tooth flanks.
Gerhard
Gerhard
