Page 7 of 18
Re: Florians FAMO build
Posted: Tue Dec 18, 2018 1:42 pm
by florian rudolf
Phil is right.
a) The secound position I did
b) don't cut the shaft nut.
You will see the hole on the top of the case over the shaft nut. I set the shaft nut in the rigt way (like I wrote it allready). Than make the hole about 3mm deeper in the brass, fixing the shaft nut with loctite, and install the pin as in the manual, also with loctite. so you have the right position for the shaft nut fixed.
Posted: Sun Dec 30, 2018 9:15 am
by Phil Woollard
Hi Florian, looking back through your thread and looking at your drive sprockets, have you bonded the rubber to the sprockets in that position ?
Posted: Thu Jan 10, 2019 10:18 am
by florian rudolf
Hello @ all,
after the x-Mass break, I'll continue my report. Made some details finish for the fame
Posted: Thu Jan 10, 2019 10:25 am
by florian rudolf
The special fasteners for the track chain, coming soon in end of March. so this one who want a set, and did'nt order it. Please PM.
I have a previos set...
Posted: Thu Jan 10, 2019 10:29 am
by David Brady
Nice details added florian
Posted: Fri Jan 11, 2019 8:29 am
by Phil Woollard
Very nice bonnet vents Florian.
Posted: Fri Jan 11, 2019 10:16 am
by florian rudolf
Thanks for the feedback. Its easyer to work on it, if you know that somebody appreciates it.
Posted: Mon Jan 14, 2019 8:27 am
by florian rudolf
Some more details. Now Iam on the window frame and the exhaust pipes.
Sorry for the bad photo quality, but you can see the rivets I have set and the new position for the handrail.
Posted: Thu Jan 17, 2019 11:17 am
by florian rudolf
I'm back, making some more details on may wind sheeld. Unfortunatly my window is broken while I install it in the frame. So I must built an new one in time...
I installed it provisionally, so not all fasteners are fixed, and I ahve'nt the wing-nut yet.
Posted: Mon Jan 21, 2019 9:24 am
by florian rudolf
Its could outside, so I worked a bit on more function details. Making the winkers.
Posted: Mon Jan 21, 2019 11:41 am
by Phil Woollard
Very nice detail piece Florian
Posted: Mon Jan 21, 2019 4:43 pm
by florian rudolf
Thanks Phil. I Hope its a good effect in the end.
Posted: Tue Jan 22, 2019 10:36 am
by florian rudolf
Yesterday I installed the mechanik for the winker and connect it with the winkers. So this work is completly done.
Posted: Tue Jan 22, 2019 1:09 pm
by Phil Woollard
Looking good. Have you bonded the sprocket rubbers in that position Florian or are they loose?
Posted: Tue Jan 22, 2019 3:17 pm
by florian rudolf
Hi Phil,
they are loose in time. Why do you ask?
I made the rubber with dubble tape, because I don't know the realy right position now.
