Page 7 of 8
Re: Firefly 008 build
Posted: Fri Mar 09, 2012 8:41 pm
by John Wiggins
Thanks Steve, for asking the question I would like to know as well!
Posted: Fri Mar 09, 2012 9:45 pm
by Derek Attree
Hi Guys
I use etch primer on brass then red oxide,,,
hope this helps
Posted: Sun Mar 11, 2012 4:47 pm
by John Wiggins
Thanks Derek, done mine with etch primer.
Now fitted.
After looking at the plans in the Hayward book, I decided to revise the rear deck.
I have made the engine compartment wider and moved the tail lights and louvers further back, so far.
I attempted to make the ventilation grate from 26 gauge rod, that I had. It's a mess, to be honest! So I'm going to remove that and start again on that part of the build. :oops:
I'm enjoying the build even more, now that I am taking my time!
Having seen the new high efficiency drive photos, I'm looking forward to the day I part with my pennies to install them in Belvedere.. On that point, and this has probably been posted before, what batteries are best to run the tank?
Once again, thanks for the help and support from everyone.
Posted: Sun Mar 11, 2012 7:28 pm
by michael hilton
Hello John, following your build with great interest, I like your improvements and add-ons. There are some serious builds on the Forum. I know from my own experience that there is a real urge to press on. I made many mistakes in my race to complete the Comet, one step forward, two back. However, I learned by the mistakes and now enjoy a more leisurely pace, these tanks are very additive though.
Keep posting.....best wishes....Mick.
Posted: Sun Apr 08, 2012 1:42 pm
by John Wiggins
Hi
Redone the ventilation grill ...... for the third time!
It has been a good learning curve, on soldering brass.
Needs cleaning up to remove the flux and excess solder.
Test fit .......
The enamel wire istemorary, untill Maplins reopens tomorrow. Needs to be thicker?
Posted: Sun Apr 08, 2012 2:22 pm
by Nick Farrugia
Hi john
your work is very impresive you have picked up that soldering very well the pics show it up very good keep the pics comming nice to see
all the best,,,,,,,,,,,,,,nick
Posted: Sun Apr 08, 2012 2:31 pm
by michael hilton
Hello John, I wondered what you had been 'up to'. The extra skills make all the difference. Look forward to your builds. Smart Firefly....Mick
Posted: Mon Apr 09, 2012 9:26 am
Looks like you've got the soldering licked :D
I've only got a couple of pictures of the grate from Bovington so I'll shrink them and post them next. Let me know if you want the full sized pictures.
Posted: Mon Apr 09, 2012 9:28 am
Posted: Mon Apr 09, 2012 9:29 am
Posted: Mon Apr 09, 2012 9:05 pm
by John Wiggins
Thanks Mick. Adrian, the photos are great. The rods on my cover are not quite right, diameter wise. All I could get locally is 2mm tube (B&Q)! The spacing leaves too wide a gap between each rod.
One thing I noticed from your photos, is that the engine cover needs to be moved back towards the ventilation grill. Should not be difficult to do.
Thanks for the help.
Posted: Sat Apr 28, 2012 11:54 am
by John Wiggins
Hi
Does anyone know how the lid is hinged, on the rear pannier of the Firefly?
Posted: Sun Apr 29, 2012 12:34 am
John, I've had a look through my pictures of the Bovvy Firefly and none of them show the bin lid :?
There's nothing helpful in the Haynes Sherman book, Hayward's Firefly book or the Modellers Guide to the Sherman.
Posted: Sun Apr 29, 2012 8:24 am
by John Wiggins
Thanks for looking Adrian. I've had a look through my photos, again! I found this one, it's not a great help, but it does answer how the first aid box mounted!
Posted: Sun Apr 29, 2012 8:59 am
by John Wiggins
Hi, had another look through the photos I took at last years tank fest . Why out of several hundred, is there never the one you want!
Regards John
