David grays Panzer 111 build
David Gray
Been liked: 1 time
Re: David grays Panzer 111 build
Post by David Gray »
Hi Kent thanks for your comments , the detail on this tank seams to be endless , everytime
i look in the panzertraks book i see something else
Dave :D
Been liked: 1732 times
small tank but hugh detail, a lot on these panzer 111s is visible, suspension, hull sides etc, never ending, but it looks stunning when complete, cracking build david. regards simon.
David Gray
Been liked: 1 time
David Gray
Been liked: 1 time
David Gray
Been liked: 1 time
David Gray
Been liked: 1 time
made a bit more progress , made the cover plates for the front space armour and riveted
them the to the brackets with 3/64 rivets , then fitted the tread plates to the cat walks
with the same rivets , a big job , but worth it, made the the anglr brackets at the front of the fenders and riveted on , also put saw cuts in the catwalks to allow
them to curve when bolted to the mounting brackets.
next job is the hinges on the mud gaurds front and rear , also the cat walk support
brackets
Dave :D
Has liked: 151 times
Been liked: 822 times
Really nice work David, although the small photos kinda limit the detail one can see. Hopefully that gets resolved so bigger pix can be loaded. Really great stuff, keep it going!
David Gray
Been liked: 1 time
Hi Bob thanks , yes this new forum is
A pain , not impressed at all
I have had to reduce the image quality
So much , so the pictures will load
And as you say it dosent show the detail
Been liked: 3665 times
We are still working on the image size issue. In the meantime your pictures are 320pixels wide. You can currently load pictures up to 800 pixels wide.
Panzer III is looking very nice Dave! Keep the photos coming please.
kindest regards
David Gray
Been liked: 1 time
David Gray
Been liked: 1 time
some better photos of the fenders
Looking good Dave! Good to see your progress.
kindest regards
David Gray
Been liked: 1 time
Re: more progress
Hi Tim Thanks , finaly got some colour on the tank , the scheme i have chosen is taken from the book , Panzer colours, Camouflage of the German Panzer forces 1939-1945
the scheme has a dark grey base panted over with dark green squiggles then large dark yellow patches, thought this would be a bit different from the standard single colours
of grey ,yellow or africa cor yellow,
I have started with the wheels first , the whole of the tank will be painted this way.
Made some more progress with the fenders fitted the front mud gaurds with some replacement hinge , this was very fiddly useing 14Ba nuts and bolts , also made the
support brackets under the mudgaurds , the holding clamp on the top and small brackets.
remade the spare track holder and fitted a bar betwween the brake vents for more links
also fitted Steve Winstones exellent headlights
Dave :D
David Gray
Been liked: 1 time
more progress made , will be glad when the catwalks and mudgaurds are finished these have been hard going
Dave :D
