Page 6 of 15
Re: Roy's StuG III (no. 2020/10)
Posted: Sun Dec 13, 2020 10:37 pm
by simon_manning
Good work going on in this stug section, just a note to you all, always allow some easy access to the internals, magnets and easy to remove decks is a good idea, and don't forget the extra weight on the front end when the motors are fitted, counter act this by setting your suspension slightly higher at the front, it will lower in time, regards simon manning.
Posted: Mon Dec 14, 2020 6:36 am
by Roy Beukeveld
Hi Simon,
Thank you for your advice, it will definitely be taken into account.
With regards to the motor weight compensation, i don't know if it is possible to balance the motors out with the batteries.
My option packs arrive shortly and then i can start measuring and balancing things out.
Or would you advice in any case (even with a balanced cog) to raise the front suspension a bit?
Posted: Mon Dec 14, 2020 8:56 am
by simon_manning
Hi Roy, Raise the front a little, the Panzer 111 and stugs do suffer from a little sag over time on the front end, and once packed with all the electrics, difficult to get at the Torsion Bar's to adjust, hold all the Electric's with Velcro so you can remove and service the vehicle, on my Kingtiger's, Tiger's there's a lot more space and freedom to do some adjustment's, regards simon manning.
Posted: Mon Dec 14, 2020 9:29 am
by yves mouton
Hello Simon,
The torsion bar setings are easy to change on the stug,
the countersink screws to change the angle are on the side of the hull and the grub screws on the bottom plate of the stug.
Best regards Yves
Posted: Mon Dec 14, 2020 2:37 pm
by Tom OBrien
Roy et al,
RE: Lifting/reinforcing the front
I'm wondering if adding springs to the front shocks would help in lieu of adjusting the torsion bars.
I've added light weight springs but since this is my first medium tank build, I don't know if it's going to assist the front torsion bars in preventing sag.
If necessary, I can always replace the lightweight springs (thinner spring wire, more "springy") with a heavier weight spring.
Tom
Posted: Mon Dec 14, 2020 9:37 pm
by Roy Beukeveld
simon_manning wrote: ↑Mon Dec 14, 2020 8:56 am
Hi Simon, okay, I will take that into account and set the front a little higher than the other arms. Adjusting the torsion bars can be done from outside the hull, so as long as the wheelarm doesn't come in front of it adjusting should be quite easy. I will show/tell how it went.
Tom OBrien wrote: ↑Mon Dec 14, 2020 2:37 pm
Roy et al,
Tom
Hi Tom, yes that could be an option as well, but somehow I'm under the impression that it will be easier to get the angle right by adjusting the fixed ends. Replacing the spring isn't difficult to do but finding the proper spring might be.
If i start out by setting the front arms to let's say 35 degrees (too much?) and the others at 30 degrees, the whole should be good controllable and adjustable.
Posted: Wed Dec 16, 2020 5:51 pm
by Roy Beukeveld
Hi everyone,
I am currently working on the wheel assemblies. When I assemble the two wheel halfs against each other I notice that the tires won't touch the tracklink.
When I separate the halfs to I guess around 0,8mm it does touch the link.
I'm thinking of printing some 45mm rings of 0,8mm thick to place between them so they can be clamped.
But the end of the shaft will then unfortunately be a bit recessed to the bearings inner ring.
Does anyone else encountered this or am I doing something wrong perhaps...?
Posted: Wed Dec 16, 2020 6:28 pm
by Steen Vøler
I can check my roadwheels tomorrow and send a picture
Posted: Wed Dec 16, 2020 6:31 pm
by yves mouton
Hello Roy,
I just look at my wheels and the tracklinks rest nice on the rubber tyres,
and there is room enough between the 2 half wheels for the trackhorns.
Best regards Yves
Posted: Wed Dec 16, 2020 6:46 pm
by Roy Beukeveld
Steen Vøler wrote: ↑Wed Dec 16, 2020 6:28 pm
Hi Steen, thank you in advance
yves mouton wrote: ↑Wed Dec 16, 2020 6:31 pm
Hello Roy,
Best regards Yves
Hi Yves, good to hear that they fit alright
Your two wheel halfs have no separation at all?
Posted: Wed Dec 16, 2020 7:06 pm
by yves mouton
Roy,
No the 2 half wheels are close fit.
Best regards Yves
Posted: Thu Dec 17, 2020 3:07 pm
by Tom OBrien
Roy,
I saw this as a potential issue early in the build. Kian pointed out that the tracks ride on the tires, so the track horns fitting in the space between the wheel halves should not be a problem as the track horns should ride high enough so that they do not have to ride between the wheel halves.
Just as a precaution, I took a large triangular file (a three-sided rough file) and filed just a small bit of metal from the top of the two wheel halves. This was relatively easy because you can leave the two wheel halves together as they are designed to be, while you file. (Of course, remove the tires first).
The track return rollers appear to be fine in their current configuration.
Tom
Posted: Thu Dec 17, 2020 8:58 pm
by Roy Beukeveld
Well I must say, I didn't notice this on forehand. I did a dry fit on the wheel assemblies but did not put on the tires...
Well anyway, the difference is very small, I made a 0,8mm thick spacer and placed it between the wheel halfs.
That makes a world of difference, the track horn now runs free with even a little margin.
Some other good news is that the option packs arrived today
A day earlier then UPS communicated, luckily someone was home.
So when the wheel assemblies are fitted then its time to figure the packs out and start making a component layout.
There may be a lockdown here in Holland but I'm far from bored
Posted: Fri Dec 18, 2020 8:50 am
by florian rudolf
Hello Roy,
think about that the rubber wheels wear out a bit. you need a little more space
Posted: Fri Dec 18, 2020 3:21 pm
by Steen Vøler
As promised some pictures
