Mr Dawe's Centurion.
- Has liked: 2224 times
- Been liked: 6945 times
Re: Mr Dawe's Centurion.
A good mornings work
Going back to the V12 has engine, I'm thinking of using one of these in conjunction with the electric motors just for the noise and smoke signature , no sound card needed, no smoke module needed, just link it to the electric motor esc's control to sync
If you were to couple the V12 to a generator you could power the motors rather than using batteries..... Didn't the Elephant have such a set up in real life?
It did indeed Mr Dawe, I hadn't considered that aspect. Anyone know what these model engines retail for?
- Has liked: 720 times
- Been liked: 1708 times
https://m.aliexpress.com/store/11024425 ... lestoreNew
Cheapest bare engine is about 3000 euros.
They have a fast idling RPM.
Engine bay plumbing, wiring, and fuel pipe for the gue, also the gue exhaust and hull fitting
Gue carburetor work, fuel pipes, carb linkage and air pipe, also more oil lines.
Just top coat painting today.
- Been liked: 1578 times
I've made a start on the radiator fan pulley assembly
The pulleys, I've decided to print slightly larger.
The fan drive pulleys tensioners .
The tensioners are now done but for top coat.
I scratched my head and came up with a simple solution.
For those that it may concern, I have washed my smart phone so email please until I source a new phone.
And I thought that the chieftain was tight for space
