Nice one, Kevin. Thanks.
The commander's cupola on the Cent packs in a lot of kit:
It is rotatable, contains the commander's optics, mounts a small spotlight and the flex .30 Browning commander's MG and has hatch lockable in three positions. The optics include:
- Seven fixed Episcopes, No 7, Mk 1 with X1 magnification.
- One Episcope, No 8, Mk 1, which can be tilted and the object prism elevated to give a view of the ground close to the tank, invaluable in Vietnam.
- One X10 binocular, with graticules to aid the commander's range estimation and allow correction of indirect fire. This sight could be replaced with an IR sight.
These optics were intended for observation only. In addition, for sighting and fire control, the commander was provided with:
- One RCP(Reflector Cum Periscope) sight, with X1 magnification and a moveable ocular of X7 magnification. A reflected graticule form the collimator, which is linked to the gunner's sight, is seen by the commander, who is therefore able to lay the gun accurately on an inconspicuous target in a very short time.
The Binoculars, Periscopic, AFV, No 2, Mk I/1:
and the episcopes and RCP sight (top, centre):
The kit cupola is very close to the original, just needing the outer lip angle to be reduced to 5 deg, the protective cover between the fixed and rotating parts to be added and material to be removed from the inside to reduce the apparent thickness to scale. I thought of all sorts of over-complicated ways to make the protective cover, including resin castings but it pays to go back to the original - I found some pond liner which is a very good simulation and it sits well on the sloping surface. Like David Wilkins, I bought a circle cutter for the mill which came in useful for cutting the retaining ring for the cover.
Next will be to correct the alignment of the episcope seatings. The template is a photo of the part from the AFV Club 1/35th kit, which is pretty accurate, adjusted with reference to photos and measurements of 064 from Paul Scott:
I have a copy of Pamphlet 15, the Royal Armoured Corps Armament Manual for Centurion, dated 1964, if anyone is interested.
Regards.
