Magnets in the hubcaps - part 2
Posted: Tue May 09, 2023 8:25 pm
Yesterday the new super magnets got delivered.
I did order a set of 20 pieces with a diameter of 13mm and a thickness of 1 and 2 mm.
The 1 mm version turned out to be perfect, although the 2mm version also will work if you want to accept a slightly
larger gap between the hubcap and the hub.
If you order them from your local supplier, get the 'N45' type, this has a higher magnetization. They do stick pretty well, it requires a bit of fiddling & and a fairly nice pull to peel them off.
