Page 5 of 5
Re: Slow build Flak36 88mm
Posted: Tue Aug 18, 2015 9:45 pm
by Phil Dawe
Paul,
your detailing is to such high standards that mere mortals like me can only aspire to!
Keep it up.....!
Posted: Thu Aug 20, 2015 7:03 pm
by Paul Wills
Stephen,
Thanks for the reply and your kind words. The original photos are invaluable when you are trying to recreate something in miniature, I hope others find them as useful as I have.
I hope to have the 88 finished so I can bring it down in October.
Regards, Paul.
Posted: Thu Aug 20, 2015 7:14 pm
by Paul Morris
Hey Paul.
you got what you were after eh
Cheers Paul.
Posted: Thu Aug 20, 2015 8:15 pm
by Paul Wills
Aye, it's turned out quite well in the end I think Paul.
how was the fishing???
Posted: Thu Aug 20, 2015 8:32 pm
by Paul Wills
Hi Phil,
Thanks for the comments. Don't be put off by what you see on here
I have no machinery to work with, apart from a pillar drill and that's why you will see a lot of plastic in my parts, because its easier to work with. You can do it, but sometimes it takes a rethink.
A few years ago I wanted a 1/6th engineers ball hammer and couldn't find one anywhere, so I decided to make one myself. All I had was some bits and bats in a box from plastic casings.
for some reason, don't ask me why! I arranged them like this
then I thought, hmmm, add some milliput
A bit of wooden dowel, then paint and Ended up with this!
Paul.
Posted: Thu Aug 20, 2015 10:34 pm
by Paul Fowler-Smith
A master class in the 'simple', lateral thinking at its best.
Thanks for showing us all the 'how' and explaining the why.
Paul
Posted: Fri Aug 21, 2015 2:19 pm
by Paul Wills
Hello,
I couldn't add the photo in the PM so to answer the question on the chain, huck and hose connectors, here are some photos.
The hose connectors, I am not sure which ones you mean. if its the ones in the photos below, I used computer motherboard pegs/spacers. Most computer outlets will have some, they come in brass or metal.
Drill it out to the size you want, then spin it in a drill/dremel and use a file or hacksaw blade to cut a groove to make it look like two nuts together.
if its these connectors,
You will need to speak to Rolf Mönke and see his post here
http://www.armortek.co.uk/Forum3b/viewt ... 3&start=30
hope that helps.
Paul.
Posted: Tue Sep 15, 2015 8:21 pm
by Paul Wills
Hi All,
Not too much progress this time. I was hoping to have it finished by the open day, but it not looking likely. ill just have to bring it as is
Paul.
