Panzer IV Build 002
Ray Brown
Has liked: 26 times
Been liked: 103 times
Re: Panzer IV Build 002
Post by Ray Brown »
i've found a gap at front after putting dvr/gnr front plate on. anyone else have this problem and if so how did you fix it? i dont want to totally fix it as i am also looking at the bridge version which has a different front & top.
secondly, what size fastener is used for the rear plate? is it the m4 csk? nothing in manual/
cheers
DSCN1157 11-01-12.JPG (101.3 KiB) Viewed 9007 times
Nick Farrugia
Post by Nick Farrugia »
HI Ray
Looking good .like what you did with the fake bolts good idea ,dont know what bolts to use ,i welded mine . I have got a gap at the front i havent sorted it yet but thinking ,a piece of angle across the front bottom edge or, you could even the top out a bit ,front and back so its not so obvious i might try this option because their are some piece ,s of angle to go on the back (not in the kit) that should hide the gap from the back ,let me know if you come up with anyother ideas ,its coming on nicely ray all the best ,,,,,,,,,,,,,,,,,nick
p.s your parcel is posted today :)
Steve Lewington
Has liked: 8926 times
Been liked: 344 times
Post by Steve Lewington »
Hi Ray
Great build photos bud she is looking good I am very much enjoying your build thank you for posting.
There is no time for peace.
No respite.
No forgiveness.
There is only ......WAR.
Kent Wiik
Has liked: 6 times
Been liked: 194 times
Post by Kent Wiik »
Hi Ray,
Your build is coming out nicely, well done!.
Noticed one tiny :oops: thing in your latest photo.
It looks as the kit front tow brackets are made perpendicular to the front plate and not at an angle inward toward the centeras as on the real thing.
Is this something you considering taking care off?
Keep up the good work
It´s all in the details!
Ray Brown
Has liked: 26 times
Post by Ray Brown »
g'day kent. i didn't notice the towing brackets. at this stage of my modeling career, :lol: , i'm not going into the detail that many of the guys do. i'll do the fake bolt stuff and over time do things like hinged mud guards, detailed opening visors etc. nice to have details pointed out for reference though.
cheers
ray
Ray Brown
Has liked: 26 times
Post by Ray Brown »
g'day all. after progressing to the air vent grills & the chinese puzzle to mount them, i've just notice a gap. i've looked at nick's & gunters as see the fins go full length. were yours short to nick and you just made new ones or where yours correct length. see photo's.
062 14-01-12.JPG (154.87 KiB) Viewed 8888 times
063 14-01-12.JPG (169.44 KiB) Viewed 8888 times
069 15-01-12.JPG (132.19 KiB) Viewed 8888 times
Ray Brown
Has liked: 26 times
Post by Ray Brown »
070 15-01-12.JPG (167.34 KiB) Viewed 8888 times
Ray Brown
Has liked: 26 times
Post by Ray Brown »
i decided to place the track on for fit & spacing. there could be a bit of rubbing at the front and reear if the mudgaurds aren't adjusted. have you tried your tracks on with your modified guards nick? all that great detail would be a waste if the tracks bang against it. i'm sure your experience already allowed for that.
068 15-01-12.JPG (180.87 KiB) Viewed 8887 times
066 15-01-12.JPG (158.96 KiB) Viewed 8887 times
067 15-01-12.JPG (233.74 KiB) Viewed 8887 times
Nick Farrugia
HI Ray
i didnt have a gap on my vents if you go to page 5 of my build there,s some good pics for you to compare ,on mine i have got a bigger space on the front end , it looks like you might have asembled it diferently you have got a small gap at the front i think thats what the problem is ,just try asembling it again ,if you still get trouble measure the vents and i will compare mine but i think just reesembling them will do the trick :D hope this helps . Your tank is coming on great and looking good keep the pics coming .
best wishes ,,,,,,,,,,,,,,,,,,,,,,,,,,,,nick
not been posting due to time , my wifes father has been taken ill ,will take some pics and that when things get better.
Has liked: 1495 times
Been liked: 1699 times
Hi Ray.
I agree with Nick. It looks like you have the vertical fins mounted on the front edge of the uprights, where as in the manual picture it looks like they should be on the rearward side of the uprights - so that the mounting bolts are forward of the upright fins.
Certainly looks a beast with the tracks on :D
Nick Farrugia
HI Ray
i have had a look at the gap on the front of the tank ,you mentioned earlier and have tried this ,the angle brackets that hold the mudguards on could be interfering with the top deck so i slackend them all off and made sure they were flush with the hull allso making sure the front mudguard fillets still fitted snugly ,then i had a look at the bottom edge of the front glacis plate and just at the edges where they touch the guards i filed a bit off at an angle ,the bottom edge is square and this was stopping the plate from sitting down on the guards properly ,i have done all this and found that the gap is reduced conciderably ,hope this helps all the best ,,,,,,nick p.s it could be you need only file the bottom edges at the ends going back to your pic of the front gap you can just see the bottom edge at each end seem to be the problem :D good luck ,,,,,,,,,,,,,nick
Ray Brown
Has liked: 26 times
Post by Ray Brown »
g'day all. after looking at the pics here & in the manual i have seen the error of my ways. thanks guys that saved a lot of head scratching. you can see on the 2nd picture the corrected result.
. decided to get a sneak peak of things to come. sat my recently aquired 1/6 dragon 2cm flak gun & gunner on top with the panzer commander i also bought. also got some jerry cans. buying while the aussie $ is good.
saving for a tiger now.
071 16-01-12.JPG (123.55 KiB) Viewed 8833 times
072 16-01-12.JPG (148.21 KiB) Viewed 8833 times
073 16-01-12.JPG (154.35 KiB) Viewed 8833 times
John Fitzsimons
Has liked: 6 times
Been liked: 834 times
Post by John Fitzsimons »
Looking good. What is weight like at this stage? Nice crew. Are you getting one of the new Tigers.
Nick Farrugia
HI Ray
like your comander, and flack guns look great too i have posted a description of the bullet guards on mine didnt want to mess up your postings with it just in. case did you see the previous post on the gap you had at the front all the best ,,,,,,,,,,,,,nick
Ray Brown
Has liked: 26 times
Post by Ray Brown »
g'day all. going away for 5 days :cry: but also :D . catching up with family & friends. going to be 35c for the next 4 days.
john - got your pm & will search forum when i get back. thanks. not sure about the weight but it is increasing slowly. yes, i`m also going a tiger pending an email to gill.
nick - got the measurements of the guards, excellent thanks. will look at front glacis again when i get home. i think i'll loosen the nuts and bolts and file the corners more, already did it before your suggestion to file.
the other thing is, did you get the hinge pins for the hinges on the dvr's and mg gnr's hatches? can't find any.
the boxes are empty as i move on to the turret and extra's from armorpax.
i've found that natural chipping is occuring on some areas that i can highlight with paints later. i recently purchased the winter weathering techniques by mig jimenez. keep me busy during the winter months.
take care all.
ray
