Steve,s Panther build
Richie Wignall
Post by Richie Wignall »
Hi Steve
Hope you are well.
This is going to be another outstanding model. I love watching your work, its totally amazing. Have you not considered building these full time? they are museum quality.
Keep up the great work, and plenty of pictures.
Richie :wink:
Has liked: 158 times
Been liked: 830 times
Steve,
I am only saying what the others have said. Your hull details are stunning, really excellent work. I'm really enjoying this thread. I cant believe the makeover to the drive case. First class work,
HI Steve
Throwing my Panther in the bin.
Your lower hull sides are simply fantastic.
fantastisch
fantastiskt
fantastico
фантастический
奇妙
fantastinen
That ought to cover it.
Really incredible work, parts and finished results. This will be one beautiful Panther model when completed.
Steve Norris
Has liked: 8 times
Been liked: 701 times
Post by Steve Norris »
Not posted for some time so heres my latest additions to the lower hull.
Thicker forward plate addded along with various servicing covers and hull drains.
More to follow
terrific detail steve, nice to have a new update, my build has been a bit slow of late, but this will inspire me to get on with it,
Antony Rowley
Location: Back to Wirral home of the brave or not so brave, England
Post by Antony Rowley »
Hi Steve,
Very nice detail 8) Your new Panther is going to be something very special.
Thanks Ant
Brian Leach
Been liked: 3 times
Post by Brian Leach »
Steve,
Schoen, ganz schoen!
Such nice work. It is a real pleasure seeing your Panther progress.
Thank you for sharing,
Brian
Steve Norris
Has liked: 8 times
After reviewing the twin torsion bar suspension i decided to carry out a very simple mod that i hope will save time and frustration in the future.
As can be seen in the photo below, the front right side fixed torsion bar is held in position by a M6 grub screw. The reason for the grub screw in this position as opposed to the normal cap heads is that the EMD mount fits directly above this point. I guess this arrangement will be OK but if access to the grub screw is required when everything is complete it would be necessary to remove the following.
1, Right track
2, Right sprocket
3, Right motor
4, Right right gearcase
5, Right EMD mount
The mod i carried out will hopefully eliminate the requirement to remove all the above components with the exception of the right Motor. All that is required is a 13mm hole drilling through the EMD mount directly above the grub screw location as shown below.
The reason for the hole being so large is that it is now possible to install a M6 cap head in this location and hence apply a much greater torque to clamp the torsion bar.
Finally heres a shot with the EMD mount installed.
If access to the M6 cap head is required in the future it should be possible to just remove the motor.
Hope this helps
Has liked: 1475 times
Been liked: 1674 times
A cunning solution Steve :D
Brian Leach
Been liked: 3 times
Stev,
This is a nice build all around-nice work, worth watching, much to see
Thanks for sharing
Brian
Marcel de Groene
Post by Marcel de Groene »
Steve,
Superb, all I can say. Very great built and nice to follow your progress and solutions you come up with. Keep them pictures coming.
Stay on tracks
Steve Norris
Has liked: 8 times
Its been a while since i last posted so i guess its time for some update photos.
Rear bin completed with jerry can stowage
A couple of shots of the rear plate with one bin temporary attached, rear plate has had its zimmerit applied.
Suspension arms painted and awaiting installation
A series of shots of the lower side plate with zimmerit awaiting final painting
Lower glassis plate detail, Zimmerit yet to be applied.
A shot showing the extended upper glassis plate and reworked interlock welds.
Next job is to paint the lower side plates and install the suspesion arms.
More to follow
nice, nice, nice, just about covers it, 3 months between posts, tooo long, thanks for posting, regards simon manning.
Magnificent details Steve! I'm afraid to go look at my Panther for fear of noticing yet another thing to fix! Your hull detail is fantatistic. I agree, post more often (kidding)!
About time! :P
Looks fantastic Steve.
