Page 4 of 5
Re: LATE TIGER I, #56 2012 SERIES restoration
Posted: Sun Dec 26, 2021 1:38 am
by Bruno Mary
I used some epoxy base paste to fill all the edges and cut-outs on the lower hull. After sanding, another coat of etching primer was applied.
Posted: Sun Dec 26, 2021 3:48 pm
by Chang
Always wondering what these two holes for? Finally realised they are for track pin deflector. Thanks Vince.
Posted: Sun Dec 26, 2021 5:52 pm
by Vince Cutajar
Track pin deflector.
Posted: Sun Dec 26, 2021 8:47 pm
by Bruno Mary
I found the following pictures on Ebay, The Armortek provided deflector does has a different shape. I also replaced the 3mm counter sunk with 4mm and threaded the holes on hull. Just debating now if I will design and machine new deflectors or just retain the original ones.
Posted: Sun Jan 02, 2022 1:15 am
by Bruno Mary
Some more progress. I designed the scalloped filets (not sure about the name) using Solidworks and 3D printed few sets.
The rivets are copper with 2mm shank.
Posted: Sun Jan 02, 2022 1:30 am
by Bruno Mary
For the scale weld lines, I first tested with Milliput by just didn't do it for me, too time consuming!
I instead opted to use Smooth-On Free Form Air, it's an epoxy dough/paste similar to Milliput but softer during mixing. I diluted a small amount of 99% Isopropyl alcohol in the mixed dough to soften it enough for a syringe application. I was able to get a smooth and consistent stream of dough out of the syringe and the application was done quickly. Once cured for about 2 to 3 hrs, I used the brass tube to replicated the weld spots.
Posted: Sun Jan 02, 2022 1:37 am
by Bruno Mary
As noted previously, my Tiger is missing the front gear case shields and the angular plates that fit on the other side of the front hull. Using some picture on the forum I started to work on the plates and was able to reconstitute the shape in Solidworks. An initial cardboard cutout was using for test fit then followed with a 3D printed part. I am planning to machine the aluminum plates tomorrow.
Posted: Sun Jan 02, 2022 11:10 am
by AlastairCooke
Hi Bruno,
Good work. My research suggests that there are only 5 studs that pass through the protector plate. The lowest one, nearest the front plate, is too close to allow for the milled pockets that protects the nuts. See image below from PanzerBasics TigerI&II CD set.
Alastair
Posted: Sun Jan 02, 2022 3:51 pm
by Bruno Mary
Good point!
Just did some more digging on the shape, there is actually no cut out on the top as the plate tapper directly to the front hull. I also guessed about 5mm thick but it seems to be a lot thinner as well.
Posted: Sun Jan 02, 2022 5:52 pm
by Bruno Mary
Updated part design
Posted: Sun Jan 09, 2022 11:58 pm
by Bruno Mary
Ran out of time last weekend to machine the plates but finally got them almost done.
Posted: Mon Jan 10, 2022 7:33 pm
by Christoffer Ahlfors
Applause, applause, applause! :D
Posted: Sun Aug 21, 2022 11:30 pm
by Bruno Mary
I had to take a break with the project since my last post, work kept me busy so as house projects.
Since then I primed the upper deck
Posted: Sun Aug 21, 2022 11:33 pm
by Bruno Mary
Red oxide applied on the hull but kept the bottom plate off, just easier to work on the suspension bars
Posted: Sun Aug 21, 2022 11:39 pm
by Bruno Mary
Setup all the suspension arms in order to proceed with assembly
