Tom's King Tiger Build 2019 Hull 53
yves mouton
Been liked: 741 times
Re: Tom's King Tiger Build 2019 Hull 53
Post by yves mouton »
Nice weathering Tom :roll:
very nice camo on your KT
Best regards Yves
Brian Ostlind
Has liked: 976 times
Been liked: 2068 times
Post by Brian Ostlind »
Hi Tom I have just put my tracks on and have the same fit that you describe above. I am curious how your tracks are now. Have you been able to remove a link yet and get them tight?
Tom Miller
Been liked: 347 times
Post by Tom Miller »
Hi Brian,
Once I finished the KT I almost never run it. Therefore, my tracks have not "stretched" so that I can remove a link set. I assume you are not able to operate your KT yet so you have not experienced the tracks climbing off the sprocket. Until a link set can be removed and the tracks pulled up much tighter the tracks will continue to climb off the sprocket when making even slight turns. Let me know if you find a way to solve this problem. I am sure everyone building this kit will be looking for a solution.
Tom
