Quad, Mick, for the use of.
Kevin Hunter
Has liked: 605 times
Been liked: 147 times
Re: Quad, Mick, for the use of.
Post by Kevin Hunter »
michael hilton wrote: I have noticed that there are eight spring plates EMO121, I have used four, I cannot see where the other four are used....
Michael, Adrian
Seems odd that the additional plates would be spares, I'd believe it more if the bag was labeled 4 yet contained 5. As it is, the parts list states 8 and the bag is so labeled which suggests to me a more meaningful purpose even though, like you, I see no clues in the build instructions. Is it possible they should be doubled up to give extra thickness, or is this a rare error perhaps creeping in between prototype and production kits?
Kevin
Has liked: 1484 times
Been liked: 1687 times
Having owned a couple I realise the demonstrator is not necessarily a good basis on which to make assumptions but it doesn't appear to have the the spring formers (EM0137).
I wonder if the original design had these flat EM0121 pieces above and below the springs but it was found this flattened the springs too much, hence the formers to assist the curve ?
Kevin Hunter
That would make sense Adrian, EM0137 added to the production kit but quantity of EM0121 not reduced correspondingly.
Kevin
Been liked: 3699 times
Adrian/Kevin
Correct!
Is there a prize :?:
:lol: :lol: :lol: :lol:
chris fry
Been liked: 525 times
Post by chris fry »
yea, four x EMO121 :lol:
Gee. Thanks. :roll:
:lol:
Adrian Harris wrote:Is there a prize :?:
wishful thinking Mr Harris :lol:
Always worth an ask .... :wink:
michael hilton
Has liked: 1566 times
Been liked: 836 times
Post by michael hilton »
Lateral thinking, never much good at that :roll: .....lots of spraying outside, while the weather holds.....
michael hilton
Had a tidy up, really need more space....should be able to start on the bodywork soon....12v sealed lead batteries and Rx arrived....Mick
Spot the difference
Spot the difference
Dave Dibb (Armorpax)
Has liked: 116 times
Been liked: 1106 times
Coming on Well!
Space is the biggest issue at this scale, I'm having to shuffle kits around again with the Quad taking up a big chunk of my main bench.
Dave
www.armorpax.net
michael hilton
Very true Dave, I feel like 'Alice' in wonderland..... :) Now, as it is ask a question day, I would like to know if it is possible to test the 'Quad winch motor' before I lock all the bodywork down. I have stripped the parts back to fit the winch cable, and thought I read a 'post' suggesting the motor can be run before everything is built up sealing the motor in situ....Mick
chris fry
Post by chris fry »
hello michael,
you really need to bench test the electrics first as the manual states, then you can test the winch, and much easier at this stage to programme the sound, then I found it easier to build the chassis up with all the electrics fitted and make sure it all works before you fit the body,
regards, chris.
michael hilton
Thank you Chris, I will go with your advice. I became enthused by how the finished Quad would look, bypassing the obvious....thanks again, :)
Here we go.....
Here we go.....
