> 5 red LEDs shining brightly in the power module.
So that's OK.
> Re the limit switches, are the connections critical?
Yes
> Mine are connected on the two outside spades of the three, but both wires are
> black.......
Assuming that means there is an unused spade between them, that sounds correct.
> Wondered if I could also test for current at the elevation connector plug with my
> circuit tester?
Better to test for voltage. A meter set to measure current is effectively a short circuit, so better to have it set on voltage instead
> It's very basic but set to DC (so not giving current itself) shouldn't it register
> when stick moved on the TX?
Yes. It might be worth seeing if you can operate one or both of the switches whilst operating the stick. Have you checked the connection between the receiver and the Aux unit ? Could one of the plugs be misaligned/backwards ?
> However, I did wonder how critical battery level is for the recoil? Mine were
> fairly low, not flat, but does the servo have more oomph on a full charge?
The servo runs from the 5 volt supply provided by the Power Supply module, so as long as the batteries are above 7 volts, it shouldn't matter how discharged they are. If the servo can affect the batteries, I doubt anything else would work
