Fitted the rear reflector.
- Rear Reflector
I moved it down a little and used 2mm bolts instead of 3mm ones. I might change them to 2mm bolts with a one size smaller head. I also made a spacer that goes behind the reflector. I think the real ones were bolted to this spacer.
- Steve's reflector and my spacer
I am toying with the idea of changing the screws which bolt the exhaust armor to the rear plate from 3mm to 4mm as 3mm nuts look a tad small.
- 3mm nut in the middle. The others are 4mm.
Still have not decided anything yet. What do you think?
