Fitted the rear reflector.
![Tiger 313.JPG (591.96 KiB) Viewed 2109 times Rear Reflector](./download/file.php?id=18960&t=1&sid=b18263f477cf73b393ba3c3960e1df31)
- Rear Reflector
I moved it down a little and used 2mm bolts instead of 3mm ones. I might change them to 2mm bolts with a one size smaller head. I also made a spacer that goes behind the reflector. I think the real ones were bolted to this spacer.
![Tiger 312.JPG (630.13 KiB) Viewed 2109 times Steve's reflector and my spacer](./download/file.php?id=18961&t=1&sid=b18263f477cf73b393ba3c3960e1df31)
- Steve's reflector and my spacer
I am toying with the idea of changing the screws which bolt the exhaust armor to the rear plate from 3mm to 4mm as 3mm nuts look a tad small.
![Tiger 314.JPG (594.76 KiB) Viewed 2109 times 3mm nut in the middle. The others are 4mm.](./download/file.php?id=18962&t=1&sid=b18263f477cf73b393ba3c3960e1df31)
- 3mm nut in the middle. The others are 4mm.
Still have not decided anything yet. What do you think?
