I use an App called Imgur to upload, then I go to my browser and visit the Imgur website and copy the “bbc” code. That code will paste into your forum post and make a picture.
Posted: Mon Nov 19, 2018 3:53 pm
by Tom OBrien
The "kids" will be down for Thanks Giving. I'll get them to help me with it.
Lame, I know but at 67 this technology has got me all buggered.
We have pretty bad experience with third party picture hosting sites here. When Photobucket changed their policy, a lot of build stories here lost their pictures and were rendered useless. Another service retained their policy, but changed the url, resulting in pretty much the same thing. If you want your build log to survive, I suggest you upload the pictures to the forum with the "attachments" button instead.
Posted: Tue Nov 20, 2018 4:07 am
by Brian Ostlind
Chassis run on rebuilt suspension. [youtube][/youtube]
Posted: Tue Nov 20, 2018 2:45 pm
by Tom OBrien
Wow, really great. Glad to see it, Brian.
No track slippage!
Did you have to move your drive sprockets out? Or are they fully up against the transmission case?
Tom
Posted: Tue Nov 20, 2018 3:08 pm
by Brian Ostlind
They are tight against the final drive cases.
Posted: Tue Nov 20, 2018 4:05 pm
by Larry Frantisak
Very nice Brian, great job!
So, what is the final track link count on each side that you finally ended up with?
Larry
Posted: Tue Nov 20, 2018 4:06 pm
by Brian Ostlind
93L. 92R.
Posted: Tue Nov 20, 2018 5:49 pm
by Brian Ostlind
I have lost or stripped out all my original taperlock bushing screws. I got some SAE replacements at the local hardware store. The replacement screws from the hardware store have a “cup” point that won’t loosen the bushing. So I just ordered these ones. They have the oval point like the ones supplied with the kit. I hope they are the correct thread. It seems they are the only American threaded part in the Armortek kit? I stripped out or lost all the originals in the dirt. The ones I found at the local hardware store only worked to tighten and not loosen the bushings because they had a “cup” point. Very confusing because the kit parts take a metric 3mm hex key but the replacements I have used take a 1/8” hex key. Is there some explanation for this?
Posted: Tue Nov 20, 2018 11:12 pm
by Tom OBrien
Brian,
I haven't had those issues with my taperlock bushing. I'm careful not to over tighten the screws and also, I use thread lock blue to help keep them from backing out.
Another option possibly is to re-tap the holes to accept a clean 4 or 5mm grub screw.
cheers... Tom
Posted: Sat Nov 24, 2018 10:12 pm
by Brian Ostlind
I just got home from a road trip and got my new set screws installed. They fit perfect.
Posted: Sat Nov 24, 2018 10:13 pm
by Brian Ostlind
Posted: Sun Nov 25, 2018 8:05 pm
by Christoffer Ahlfors
Worn in.
Is there anything left of the paint on the tracks?
Posted: Sun Nov 25, 2018 8:38 pm
by Brian Ostlind
Yes Christoffer, the black paint is everywhere that does not touch the wheels or the ground. The areas that touch the wheels are completely worn down to the metal, and so are the pads that touch the ground.
