OPEN ON THE 6TH FEB 2025
Brian's 2017 NO. 10 LATE TIGER 1 BUILD
Brian Ostlind
Has liked: 971 times
Been liked: 2066 times
Re: Brian's 2017 NO. 10 LATE TIGER 1 BUILD
Post by Brian Ostlind »
After a few smacks with a hammer I think I have the right side wheels and tracks meshing perfectly!
I did remove one link on the right.
[youtube][/youtube]
Brian Ostlind
Took a link out of the left side. I am tired now but the perfect weather has me driving this thing like crazy. I need a back brace from all the bending over...and a second pair of batteries!
[youtube][/youtube]
[youtube][/youtube]
Tom OBrien
Has liked: 5 times
Been liked: 67 times
Post by Tom OBrien »
Adrian Harris wrote:
Sun Nov 11, 2018 9:10 pm
> haha this thing is awesome!
The addiction is taking hold :lol: :lol:
> I will tighten the track.
Don't forget that when you add the turret the weight will compress the suspension and make the tracks looser.
That looks like a nice median to drive on -- gravel isn't too large to get caught in the running gear.Although Armortek recommends 96 tracks per side, I found this to be way too loose even when the track tensioners are at their taughtest. On the other hand, in an attempt to solve my de-tracking problem, I went to too few tracks (92) per side and, although it alleviated the de-tracking, it also broke two tracks when carrying gravel into the drive sprocket. My next move is to remove some metal from the idler axle to bring the idler wheel closer into the hull by 2mm. I'll add tracks back so that each side has 94 tracks.
Batteries: I have two 22 Ah 12V Sealed Lead Acid (SLA) batteries that fit nicely into the compartment. The run time is around one hour with the sound engaged. You can order the SLA batteries on line for about $40 each. I would also recommend setting up an on-board 24V charger, which is relatively easy to do. Your charger device should handle 5-10 amp hours, which should take about 3 hours of charging time.
Has liked: 775 times
Been liked: 1742 times
So what's the latest track link count? 93 on the right and 94 on the left?
Brian Ostlind
I think so!
Vince Cutajar wrote:
Sun Nov 11, 2018 11:43 pm
Brian Ostlind
My sprockets are still coming out of the tracks. I think I will ad more chamfer. Should the chamfer be even all around or more extreme on the inside of the sprocket rings? The pictures and drawings show a small taper but that is what I have got now and I am planning to file it down to more of a triangle shape. I hope it solves my problem so I can make harder turns without loosing the track.
Brian Ostlind
Brian Ostlind
Added chamfer
Christoffer Ahlfors
Has liked: 729 times
Been liked: 332 times
Post by Christoffer Ahlfors »
Brian Ostlind wrote:
Mon Nov 12, 2018 4:16 pm
Not sure. Judging by your pictures, you have more chamfer than I do on the sides and it works well enough for me. You may want to add a bit of chamfer to the front and back of the cogs. This will stop the crackling noise and make the drive silent. It will also prevent the track from clinging to the sprocket. It will not help the tracking, however.
Brian Ostlind
At this point I am super frustrated and drained. I spent all day crawling around trying to get my tracks, wheels and sprockets all lined up and I just can’t win. No matter what the right side tracks come off the sprocket. I filed the rings down so much that now they look like shark teeth. It didn’t help. I tried tight tracks, and loose tracks. Nothing is working. I even moved ROADWHEELS out on the torsion bars. It will not make a left turn. The only thing I can think of now is taking it all apart and starting over. I will probably need new sprocket rings though since they are severely filled down. Also, my tracks curve when I lay them down flat does that mean they have a problem?
Tom OBrien
Has liked: 5 times
Mon Nov 12, 2018 10:08 pm
Brian, it sounds a lot like the problem I've encountered with track slippage and de-tracking.
I went back and chamfered my sprocket teeth inside and outside of each tooth just a little more than I originally did, but I hesitated filing too much off so that it weakens the teeth.
On my tiger, the idler wheels do not line up even when they are installed according to the instructions.
I tried placing washers on the road wheel axles so the road wheels sit outward from the hull but this allows only a couple of mm.
My next move is to have someone machine the idler axles so that the idler wheels can sit 2mm closer in the direction of the hull. I'm guessing the fact that the idler is misaligned is forcing the track outward just enough that the track sits on the last road wheel rather than fitting into it (resting on top as it should).
I think it might be time to bring Kian into the conversation as I would think it's a universal problem, and not one with only a few customers.
My opinion at this point is the idler is the problem and not the rest of the suspension (swing arms, sprockets and wheels). It probably should have been designed to allow the idler wheel a more exact alignment with the road wheels.
cheers... Tom
Tom OBrien
Has liked: 5 times
Not sure what you mean regarding the track curve when you lay them down flat. They should lay in a straight line, unless they're binding because of paint or something inside of the track rings where the pins go. I didn't paint my tracks completely, only the ends with the end connectors. I used a simple grey spray primer and it worked very well.
Brian Ostlind
They can be pulled straight but they have a left curving bias. Out of the box not from painting them.
Tom OBrien
Has liked: 5 times
That's normal. So long as you can lay them out in a straight line, I think you're good.
Brian Ostlind
Ok good. Right now I am driving with the sprocket pulled far out and it’s ok but can’t make hard turns.
